Need help preparing for headlight swap.
ElDiablo
Car: 2008 RedAlert Nissan Versa s
Does anyone. Have a good guide on removing the headlights. Also wireing for projector hid's.
weems84
Car: Versa SL
first thing to do is remove the grill completley and then go to the the wheel well and remove the inside cover. There is a blot hiddn there that holds the headlight in place. Once that is done you can easily see the bolts and remove the headlamp. For projector wiring I removed the bulb holder that they attached and connected the power and ground to the ballast. So you still have the factory h4 plug connected to the headlamp plug. Just splice the low beam wiring and connect t it to your hid hook up. That's about it.
ElDiablo
Is it difficult to remove the inner wheel well?
weems84
Car: Versa SL
the joint where the bumpber meets the side fender is wuerethe bolt is hidden. You don't need to take the whole thing off. Once you crack it open a bit you'll see a screw holding the bumper to the fender. Remove that then you'll see the bolt holding the headlamp on.
weems84
Car: Versa SL
I think the thread that shows you how to do blackhousing on the headlight has pics and instructions on how to remove it. That's what I used when I did mine. Just do a search
ElDiablo
The black out light post that i found didn't have any, how to disasseble instructions, but i think i know what your talking about. I think it was the black out grill post. I will try and find it.
The bolt you were referring too, is it what connects where the two meet in these pictures?
weems84
Car: Versa SL
yes. When you take that bolt off it provides a small viewing space to remove the bolt on theheadlamp
ElDiablo
Cool, thanks for your help.If anyone wants to add anything that might make this a easy process, i sure would appreciate it. Probably going to start it tomorrow morning, if its not too cold.
weems84
Car: Versa SL
check out this thread---> zerothread?id=339639
and this one---> zerothread?id=347325
I used a combination of thses two threads on how to do it. In one of the posts there is a crappy picture of the back of the headlamp with the hid bulb in their. You can see the hid in there and cut through the seal to push the plugs through. You can also see how i cut the wire directly off the plug on the headlamp to connect to the ballast for the low beam and left the high beam as is.
low beam---> H3 HID 5000Khigh beam---> H1 halogen
ElDiablo
that helps, thanks.
I have taken the front apart, that side bolt that holds the headlight under the fender was a ***** to get off without taking the bumper off. I cracked it loose and it was able to come off by hand after that.
Next i need to rewire the Hids.
This is the wire for the main headlight.
Green, Black, Blue. The other lights dont have to be altered because they plug directly into the headlight.
But the HID has to be split because it has seperate bulbs on the headlight.
I know bob from versa speed has done this.
Other then that anyone else know of the 3 wires which is ground, which is hot...etc?
weems84
Car: Versa SL
Don't cut the factory wire. Do it on the headlamp itself. Just follow the wires coming out. One wire hot to low. One hot to high. You'll see one split going to both(ground). Cut your low and one ground going to low and your done. I would take better pics to help but I'm at the airport going out of town now.
ElDiablo
Thats a good idea, it would be a hell of alot easier for me to just crimp them together, but if i keep it stock it might be better in the long run in case i want to upgrade at some point in time.
I just have to figure out how im going to get all these wires to fit in those tiney little holes.
The headlamp was used when i purchased them. From the looks of it he already had it wired to plug up. Im guessing the lose red wire was ground to the frame.
He didnt send the caps for the back of the HID compartment, so i hope that doesnt present a problem with the elements, as you can see how dirty the compartment gets in oklahoma.
ElDiablo
ran into another snag in the scheadual, one of the bulbs was burned out.gotta find me another today hopefully. dealer only item.
ElDiablo
craptastic! no go, everyone closed tomorrow, dealer near my house played martard.
Going to order online, and run though the dealers. takes d2r d2s or d2c 12v 35w
anyone got any recommendations would be loved very softly until your muffled screams are faded away.
ElDiablo
Question...
Is the versa prewired for fog lights?
When i took my bumper off there were wires with connectors already attached to it hanging down off the bumper.
I will take a picture of it tomorrow.
ElDiablo
Here is a pic of that cable that was just hanging there. Its on both sides?
Here are the new headlights, man they are sexy as hell.
Last but not least, i am selling my factory headlights on ebay. 200 bucks if anyone is interested. I think i may have the shipping wrong, i will check it tomorrow. also, just listed them today so they may not be on there till tomorrow. Perfect for making your own blackout headlights like in the how to articles.
thanks for the help again weems.
Modified by ElDiablo at 5:51 PM 12/7/2008
bulld0g
Car: 2007 Nissan Versa SL "Bulld0g Edition"
yes the Versa's prewired for foglights and that is the cable. BTW the headlights look good
Atx_Versa
Car: 2008 Nissa Versa SL
Nicely done ElDiablo...Lets see some night pics!
ElDiablo
Im waiting on the bulbs to come in via the snailmail due to no one carrying them local that i could find affordablyish.
ps. fixed the shipping on my (original) headlights on ebay.
If they dont peak any interest i may mod them myself and relist them.
I will post pics as soon as i get the bulbs in.
