Service:
When mechanic looked at the bottom he saw that power steering solenoid valve was strangely modified in his opinion
The holes for valve ware badly welded with tiny holes and also no cable was found
He changed seal on both valves and added fluid.
He than checked and the power steering control unit was where it should be, but again no cable to be found.
When I got home after hard testing, hard acceleration (to the rev limit) and hard turning I checked fluid level and it was again below COLD MIN and the car was hot.
My questions are:
I this normal that there is no cable and the holes are welded?
What to do if there is still leakage. I will go to him to check again if there is a leakage and I will added fluid.
