evildky »
https://forums.nicoclub.com/evildky-u13100.html
Wed Apr 11, 2007 6:16 pm
first of all, your a/f meter, means nothing not usefull unless your playing with the engine managment or forced inductiona dn even then useless unless its wideband
second, your "scanner" shows a leak?
third, your fogger? so you have some sort of smoke machine that pumps smoke into the intake with the engine off and the intake sealed up and it also presurazes the manifold to 10 psi?
4th, I realy don't know why you even bothered to mention what brand of suspension you have for diagnosing an engine noise?
sorry if I come across as a ball breaker that isn't my intent, it's just that if you have a legitimate problem we need as much pertinant info as possible and the stuff thts completely unrelated sush as your suspension you should leave out
and for the sake of argument we'll assume you have checked all your hoses and topped off your coolant
now does this hiss present when the car idles? is there any drivability issues? does it make the noise if your not using climate control before shutting down? could the noise simply be the freon passing through the system as you shut the car off?
