Roger_cha »
https://forums.nicoclub.com/roger-cha-u47520.html
Wed Mar 31, 2010 11:01 pm
to make the story short, i did a compression test on my ka when i put the hose inside the spark plug hole with the extension adapter, then after i did the compression test i try to take it out and the hose came out the the second piece didnt came out its stuck in the spark plug hole so i try to put it back in and take it out but the hose only came out without the adapter with it so i put in a spark plug in it cause it will screw into the adapter as i was tighten it the whole thread just snap off so now i have no way of getting it out but im not sure if drilling it out will do cause i dont want to damaged the inside of the head, can anyone give me some advice or know any tools that ill help me get it off, any help would be appreciated thanks.
