slidingA240sx wrote:hay guy i just did a tb belt and water pump on my ca it ran awesome for a day the it just back fired and died now it wont start i changed the plugs cuz they were socked with gas
ps timing is dead on i set the timing to 10 deg at first it was breaking up in high rpms so i set it to 15 deg..
please help im out of ideas
thanks josh
Are you sure your cam timing is correct and not your ignition timing? If everything is spot-on, then you have issues with y our crank angle sensor or related compnents as suggested by zero.
Dee
