nametakennow »
https://forums.nicoclub.com/nametakennow-u713.html
Wed Mar 12, 2008 5:31 am
Does the gauge bounce around after the car has warmed up? If so, is it on-throttle, off-throttle, or all the time? Regardless, if it's moving then either the temp sensor is bad or there's an air bubble in the coolant system.
Generally such issues cause a rough idle and maybe stalling/bucking.
What codes are you getting? Fairly minor codes, particularly in combination, could explain the symptoms.
Bad injector, O-rings, fuel pump all are still in play.
