Beancooker »
https://forums.nicoclub.com/beancooker-u42602.html
Mon Sep 18, 2006 2:53 pm
The switch has to be correct to start. It needs to be a closed circut that opens only when switched. You simply cut one of the wires on the resistor plug and splice in the switch. I wired mine with a flip switch in the dash, because I drive at WOT a lot and don't want to hard shift the transmission that much. If you go to the search option and search VB mod in the Maxima forum, topic body, you should pull up a post where maxhopper tells of a good shop to order the VB mod kit from. Not sure what "is there anylike shift kits" means. A VB mod is a shift kit. One in the same. It modifys the valve body in the transmission.
