Eikon »
https://forums.nicoclub.com/eikon-u15727.html
Tue Nov 08, 2005 6:39 am
If multiple windows are inop at the same time it is clearly an electrical issue rather than mechanical issue.
Typical electrical issues with power windows is a disconnection in the circuit. In other words a blown fuse, bad ground wire, disconnected plug or relay, etc...
ewittiner is right on.. Many people don't even think of the obvious driver's side power cut-off... The "child proof" switch.
Check that first. Don't be embarressed if that's it. It's a common mistake.
First check your fuses to make sure they aren't popped. That is the most likely case.
If that's not the case... You may have to take off the passener door panel to make sure the plug is connected properly. Also, take apart the center console and check the grounds to the window swith.
Keep us posted, and we can help you work through it.
Good luck!
Nice to see you here in the vert forum.. don't be a stranger. Post some pics of your hot 'vert.. We love pics!!!
