Need help Please No Start
jdog300zx
Car: 1990 nissan 300zx
recently i just got the z back up and running and i took it for a ride around the block and it stalled on me and wont start back up, it cranks but doesnt start. i just put a brand new ignition control module in it, has a new battery, and new battery terminals.it also has a new starter. i dont know where to go from here.
nissanfreak12
Car: 92 300zx 2+2 TT
Do a self diagnostic on the ECU, that is the next step you should take. That should point you in the right direction. Let us know what you find.
http://www.google.com/url?sa=t&rct=j&q= ... TVZLDsrwpA
GerryO
Car: 1993 J30t
Pearl White
Black Interior
jdog300zx wrote:recently i just got the z back up and running and i took it for a ride around the block and it stalled on me and wont start back up, it cranks but doesnt start. i just put a brand new ignition control module in it, has a new battery, and new battery terminals.it also has a new starter. i dont know where to go from here.
The ICM was replaced before the ride around the block? Check the CAS, TPS and MAF, and their connections. Nothing is wet or damp? Try an extended cranking session with the gas pedal held to the floor. Got the correct spark plugs? Your current set could be fouled by now.
Check the IAA/AAC/FICD valves and the Air Regulator, for vacuum leaks and the engine timing.
http://www.mdsmarthome.com/z/Z%20Tech/Z ... 20Idle.pdf
jdog300zx
i just put new plugs in it i will check all these things this weekend. thanks for the tips
GerryO
Car: 1993 J30t
Pearl White
Black Interior
NGK LASER PLATINUM SPARK PLUGS
PN:PFR5B-11B
APPLICATION: 90~96 NISSAN 300ZX VG30DETT VG30DE FAIRLADY Z32
jdog300zx
my plugs are NGK but there the cheaps ones you but at napa i dont think there the laser platnuims
and the car is a 1990 na 5 speed
GerryO
Car: 1993 J30t
Pearl White
Black Interior
jdog300zx wrote:my plugs are NGK but there the cheaps ones you but at napa i dont think there the laser platnuims
Some searching might yield a number of wrong plug stories.
http://www.youtube.com/watch?v=GhaW8j6RbJE
NGK PFR6B-11 are colder plugs. I have them in my J30, but the key is NGK platinum and all of the other numbers/specifications. Figure it has some thing to do with the VG30DE CAS and six individual coilpacks configuration.
nissanfreak12
Take those out, they could work, but will run like crap or not have the performance you desire. Have you checked the ECU for codes yet? Until you do that you are just shooting with a blindfold.
