Wc240 »
https://forums.nicoclub.com/wc240-u133792.html
Sun Jun 21, 2009 6:32 pm
Dont get your panntys in a bunch. i was helping and apparently i didnt do a good enough job to your satisfaction.im so sorry. ill elaborate.By me saying that you have WIRING ISSUES i meant that, well, you have some wiring issues. start checking/tracing your wires. make sure there wired right, ran clean(none worn thru and touching metal or other wires) make sure their hooked up right. it sounds like you have either frayed/bare wires touching some metal or other wires. Also to check, because this can easily happen, make sure when you put in the motor that you didnt pinch the harness anyywhere. hope that helps, and in the future you dont need to get pissy when someone gives you a quick answer instead of a long drawn out one.hope you get it figured out
