gingerbredman »
https://forums.nicoclub.com/gingerbredman-u67700.html
Tue Sep 29, 2009 8:37 am
Oooh I had a very similar problem not too long ago. It turned out the wires connected to the alternator had burned almost completely off. After using an ohm meter to test voltage at every source and in-between it turned out to the connections at the alt. I completely replaced the two main ones with 8-gauge amp wire and shrink-wrapped connections and haven't had an issue since.
OH! I noticed that within a couple of minutes while the car was running that the one hot wire on the back of the alt was extremely hot, before I fixed it. I drove a few miles from college one night and headlights got dimmer and dimmer until the car completely shut off.
