cory2081 »
https://forums.nicoclub.com/cory2081-u9472.html
Mon Sep 13, 2004 12:23 pm
There is a weep hole on the water pump that is right behind the waterpump pulley. You can put your finger on it and see if it is wet. (that totally doesn't sound right, but, anyway) Mine did this a few months back, there would be a small puddle under my car sometimes after the car sat for a little bit after driving it. Turned out that the seal in the water pump was going bad. The water pump is very easy to replace, and only costs about $25 or so!! Hope this helps!
