need help painting!
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
FD3S
i was planning on doing some touch ups on my versa and i was wondering how you would go about doing that
i want to repaint the steel rims black because it is already faded
and there are also some chipped paint parts on the body that i want to touch up
what will i need to repaint the steel rims and chipped paint?
i already have some magnetic gray paint mixed up from a body shop
will i need clear coat or anything else?
thank you!
FD3S
can i also paint the steelies without taking off the tire (just put tape/newspaper over tires)?
KimberKenobi
Car: the Camel
FD3S wrote:can i also paint the steelies without taking off the tire (just put tape/newspaper over tires)?
yesh
I'd make sure to use wheel paint and also wheel clear to seal them.
as for the body stuff, I assume you need the paint you got mixed and a clear coat... but I've only done my plastic bits and I used wheel clear on them too...
Return to “Versa Technical Discussions”
