need help, only one headlight working
VirginiaPS13
Car: 89 S13 Coupe
2005 Acura TL
First things first ive searched and cant find exactly what I need and ive been working on this thing for 2 days now and its pissin me off. I have a 89 coupe with the pop ups..everything works fine they come up go down hi beams work but with the low beams on, only the passanger side works. Ive checkd relays and fuses all fine and of coarse i get power on a meter, at both lights when on high but when i go to low beam im only showing volts on the pass. side. So I guess my question is, could it be the switch on the column causing this? Any imput would help, And please No SmartA$$ remarks, please keep them to yourself.ThanksBrad
broke1990240sx
Car: 1990 nissan 240sx
i have a similar problem with my 90 when i flip up the lights they flip up but don't turn on. i checked the plugs with a meter and only the passenger light gets power but only the high beam. but it doesnt turn the light on. ?? weird any help will be great.
dgms240
Car: '90 s13 hatch ka24det
i have the same problem on my s14. it is definately the combination switch on the column. from what ive learned, they tend to short out, and it seems to be one of the many common issues with the 240sx.
vancouverbc
Car: 1991 240sx
VirginiaPS13 wrote:First things first ive searched and cant find exactly what I need and ive been working on this thing for 2 days now and its pissin me off. I have a 89 coupe with the pop ups..everything works fine they come up go down hi beams work but with the low beams on, only the passanger side works. Ive checkd relays and fuses all fine and of coarse i get power on a meter, at both lights when on high but when i go to low beam im only showing volts on the pass. side. So I guess my question is, could it be the switch on the column causing this? Any imput would help, And please No SmartA$$ remarks, please keep them to yourself.ThanksBrad
probably the switch
look for headlight in tutorial link in my signature
VirginiaPS13
Car: 89 S13 Coupe
2005 Acura TL
I replaced the switch and didnt work..but that web page with the FSM's is bitchin'....Found the problem..traced the wires back and found the wire was cut/smashed?? dont know how but i soldered it back together and put some heatshrink on it and its good as new.Thanks 4 tha link to the FSM's
vancouverbc
Car: 1991 240sx
Good job:)
