Xeen »
https://forums.nicoclub.com/xeen-u33749.html
Thu May 04, 2006 2:30 pm
My suggestion is to use a block of wood and a piece of rag as a buffer while hammering. I held the knuckle was held in a vice. This was while I was doing a 5 lug swap on my 1996 240. The rear hubs and knuckle assembly can be a pain, even if your car is rust free. After you bust it loose sand the knuckle (with light sanding paper) to ease the installation of the hub.
Note: there is a large ebrake bolt that must be removed before you dissasemble the 300zx rear hub spindle if you got these pieces assembled.
I hope this helps!
Nathan
