1200dollrdriftr »
https://forums.nicoclub.com/1200dollrdriftr-u4817.html
Tue Feb 04, 2003 12:27 pm
just because your car isnt gettign good gas mileage doesnt mean your runnign rich, you might be leaking fuel, check for that. if you are running rich you should be able to tell, does it break up at all? backfireing a lot? putting an air and an exhaust temp. gauge is a good idea and will tlel you if you are running rich or not. if it is you can get an apexi SAFC to fix it, or basically any type of fuel controller. and by the way what kind of fuel pump are you running?
