altima coupe wrote:You can't use them. There is a 5.48% difference between these and the stock tires. That's greater than te recommended max of 3% difference. This could cause brake failure and issues with your ABS and TDC.
You will have to bite the bullet and get proper sized tires.
I'll have to disagree with altima coupe on this one. If you're going to run them on 16x7's, you should be ok. At that size, you don't have to worry about rubbing or anything like that. The only thing you really need to worry about is total tire diameter. OEM is 25.5" and going down to 24.9" shouldn't be that great of a deal. Your ABS shouldn't act up, but you may get TPMS readout from your computer unless you have TPMS in your new tires.
