Need help on swapping a 95 KA into a 92 240sx
sleepyeyes
Car: '93 240sx Fastback
Im about to get my hands on a KA24DE+ transmission from a 95 sx and im gonna install it into a 92sx. What things will i need to watch out for and get for this swap?
Just for more insight on exactly what im getting heres what the guy im buyin the motor from originally wrote...
"Selling a KA24DE+ transmission from a 1995 240sx with ~120k miles. Engine still runs excellent, and I still have all the service records for it. It is currently still in the car, so potential buyers can drive it before it comes out. I am selling the engine and transmission combo, including all the accessories (ac/alt/ etc. etc) . What will not come with the engine is the main harness, the speed sensor, and temp. sensor. (those items can be easily picked up at any junk yard). I need these pieces for my SR swap."
Just another thing, your probably thinkin to urselves, why a ka24de swap instead of a sr20 or rb26, cause i cant afford it right now plus the motor in the 92 isnt workin. And this is a pretty cheap alternative. So any help on this swap will be greatly appreciated. Thnx
Emperor240
i did that exact swap, the only thing that i had a problem with is on my 92 motor the heater hoses were on the intake side of the engine and on the 95 they were in the front so they had to be switched over and i belive that was the only major difference, except your engine will sit a lil higher if you use the 95 motor mounts
