NEED HELP ON SWAP!! SOOO CONFUSED!!
SR20S13
Car: 1993 Nissan 240sx - SR20 INSIDE....
ok got a 93 hatch and i put an s13 sr20det swap ofcourse but i was gonna use the stock rad. for now but the sidemount "cold pipe" wont work w/ that rad.!! should i go ahead and do front mount int. or what? also the trans. sensors are diff. the ka there is like 5 on the transmission and the sr there is like 2 or 3...idk im confused! some help would be awsome!! thanks!!
SHIFT_240sx
Car: 91 Nissan 240sx SE Coupe
double post
SHIFT_240sx
it works trust me, keep trying, youll get it, if not and you have the cash get an sr rad, or better yet koyo so you wont have to make a crosover hose, and if you have any more money, buy an fmic.
from what i remember from my swap, you should switch the speed sensor from th ka transmission to the sr transmission, if you have the sr lower harness with transmission harness everything else should work, if you are using the ka lower harness youll lose te neutral switch and reverse switch(no reverse lights) and thats about it
duffman1278
Car: 89 240sx Hatch, the wildcats!
Just like shift said, switch the plugs from the KA onto the SR. As for the SMIC, YES it will fit, you just have to make some minor adjustments on the radiator hose. The IC pipe from the throttle body might not clear PERFECT under the hood, but it'll fit. It'll be kind of tight though, nothing extreme. GL
schanne
Car: 93 Hatch-Sr20
Go get yourself a Fmic and rad. It cost me less than $500 for both and there pretty damn sweet!
