180fan »
https://forums.nicoclub.com/180fan-u3602.html
Sat Jan 20, 2007 11:13 pm
audible clicking - normal for the INJECTORS, anywhere else please let us know.
stuttering during the power band, did you check your turbo?
oscillating idle, did you check over your iacv and also for vac leaks? in a worst case scenario, it can also be your mafs or mafs wiring. I can testify to having had the mafs cause that problem.
Did you also do a plug read? pull your spark plugs and tell us 1. color 2. any wear on the electrodes 3. foreign liquids on the tips
