need help on SAFC settings...
DriftinNC
Car: Sr datsun 510
I got an safc1 from 1 of my friend's for a good deal, and was needing something sooner or later to tune my car with. I searched topics on this but had no help. Im pretty sure im running a little lean, or it might be the turbo going bad or some other problems....i have white smoke at idle, and sometimes when my engine is on a load. I tried to get a few things to richen it up, but doesnt seem to help, so im going to install the safc tomorrow but im not too sure what settings i need with my little upgrades i have.
Here is the list of mods1. fmic kit2. k&n filter3. 3" full exhuast3. z32 fuel filter4. walbor 255 fp5. dsm 450cc injectors (i still have stock maf,stock turbo and running stock boost)
Ill be going to Turbo Tune in a few weeks to get it dynoed and tuned a little more for higher boost, but i just need some settings for now, so i wont mess anything up. Thanks for the help in advance
Michael
T88lexus
with stock T25 with 450cc injector.. you are not running lean. you are running rich as crap.
I can still run sr20 T25 with stock injector, stock maf, stock fuel pressure with 12psi.. A/F is at 12.4 at the max. injector duty at 89%
unless you are running sr20 T25 or bigger.. you do not need of 450cc injector. nice to have if you are planning to go bigger. but if not. stick with stock injectors. if I were you .. I would just a get a aftermarket FPR to rich up the fuel pressure and be done with it.
but if you want to run safc with 450cc that is fine too. as long as you can tune it . you know my number and let em know when you going to give me the moeny..
DriftinNC
Car: Sr datsun 510
well, looks like ill be heading to your place again soon so you can help me tune my car and so i can buy somemore parts you got for sale
