paysonboy801 »
https://forums.nicoclub.com/paysonboy801-u33349.html
Fri Mar 03, 2006 7:15 pm
does it seem like it has any spark at all? even if the distributers set in there backwards it would still start you would be fouling out every spark plug you have but it would start, my suggestion would be check the fuel lines, make sure there connected correctly. I pulled that one on a 280z I used to have, I looked like an idiot when I brought it to the shop finaly. I havn't really gotten that far into my 240 as to try fixing stuff that aint broken, but it looks to be the same set up as the 280z where the distrubter has a bar that goes straight through to the oil pump. I could be seriusly wrong on this one though. if I am then I would be happy to get some pics of how the distributer should be set up. and you should check the wiring for the coil alot of people I know who have rebuilt or done anything motor wise have put the wires on backwards
