msaskin wrote:Uhhh...and how pray-tell do you think the SAFC is used for fuel tuning?~matt
The SAFC gets the voltage from the MAFS, then changes that voltage before going to the ECU.
So if you turn up the knob to increase fuel, you are just telling the ECU there is more air than there actually is. Turn it up 50%, it tells the ECU there is 50% more air than is actually flowing through the MAFS. The ECU makes the changes and injects the proper amoung of fuel to the stock injectors. If you change the injectors, the ECU may not send the right signal depending on the size of the injectors.
So you see, the SAFC intercepts MAFS signals before they reach the ECU and changes them. Then the ECU unknowingly dumps more or less fuel in accordance with that newly altered MAFS signal. The SAFC does not tell the ECU how to run newer larger injectors, for that you need a piggyback, standalone, or rechipped ECU. Though you can sometimes use larger injectors that take the same signals.
