Camel »
https://forums.nicoclub.com/camel-u8564.html
Mon Jan 19, 2004 11:07 am
You don't have to repin the cam. I searched on this extensively and found that you can rotate an exhaust cam 4 teeth to correct for not repinning it and you will have 248/248 which is the same as the nismo cams.
do some searching and you will be able to get the info you need. if i remember correctly, it referenced an offsite link.
