hysteria »
https://forums.nicoclub.com/hysteria-u25294.html
Tue Apr 26, 2005 2:53 pm
it's ssac. posts related to "should i buy this great priced kit off ebay" referring to ssac or xs power or any affiliates have been officially banned by the admins around here because every time a new user starts posting up on these forums the first thing they tend to bring up is ssac and "is it worth it", etc....
if you want answers do a search pertaining to ss autochrome, ssac, xspower, or anything related to it. there have been a ton of posts about the topic. this post will probably get deleted, so before it does go do a search and find out about ssac kits.
many people have them and they work fine as an entry level setup but don't expect it to be something it isn't... great quality stuff that will last forever and do whatever you want it to... $700 won't even buy you the necessary manifold to make the kinds of numbers a lot of people on this board make... (eh this might be a stretch but you get the idea that the quality stuff isn't cheap)
if you are fine with 7 psi then get it. many of the parts work fine (as jrl said) but some of the parts are crap. in addition to this you're not going to make 300hp with a fmu setup. learn more about fuel management and the different options and costs of all of those options....
don't take this as a put down because it's not meant that way, but chances are that if you're looking at a $700 turbo kit you don't have a good concept of what actual power to the ground is, and what reaching certain power goals entails. making 300 hp isn't exactly cheap because the fuel management required to do so will cost a good amount (much more than that $700 kit for sure for better injectors, fuel pump, maybe fuel rail, fuel management electronics and other things required). all the information you need is within these forums, you just have to use the search button. good luck.
