480sx »
https://forums.nicoclub.com/480sx-u50548.html
Tue Nov 06, 2007 7:01 am
Everything i have read, from the big guys(turbonetics, garrett) say that the use of an oil restrictor is a last resort.
JGS however says that anything over 50 psi and you need a restrictor. Im not placing nearly as much faith in JGS as i am turbonetics and garrett though.
Typically a journal barring turbo is run without a restrictor. One would be added if you notice that your car is burning oil, and you have done everything to try to fix it. Basically making sure that your oil drain is 100 percent, making sure your air filter is not so clogged that its causing a vacuum effect and pulling oil out of the turbo, and a few others. If all of that is good, and your still having over oiling issues, then you put a oil restrictor right before the turbo.
Its so simple to add an oil restrictor.. So what you want to do, IS wait for the oil pressure to go to high, then add one.
