!!need help. on my new rb20!!!
joeythemech
Car: s14
Well i just finish the swap in my s14 it runs ok!!!expect the sputtering and overheating.I put a new 2 core radiator with 2 dual fans and it fixed it when am cruzing around. but when i run it hard the heat shoots up rite away. can anybody help me with that and the sputtering is when i jump on between 3500rpm and 4500rpm it strat to sputter then goes away. .i check for boost leak i found nothing plz help me?
dizzywithsunstroke
Car: 1995 Nissan 240sx w/ RB20DET and 1997 Nissan Hardbody
i am finally getting my swap running good now after 2 years. did you replace gaskets and compression check your motor?
Carl H
if you're using the rb thermal transmitter then the stock gauge will read wrong.
Fibre guy
Car: 91' s13 RB25DET, 95' s14 bone stock, 87' Wrangler 4.6L stroker
Did you rebuild it or throw it in?For the sputtering, did you by any chance, in an exited panic, forget to check the spark plugs...? Damn engine gnomes!
