DALAZ_68 »
https://forums.nicoclub.com/dalaz-68-u62157.html
Fri Sep 28, 2007 10:24 am
if the starter isnt getting signal... obviously its starter
if u have no spark...check ur ecu if its tightened down properly, that was a problem with mine...and it fired rite u after that
check the starter module above the ignition coil
autozone has a tester there...tell them to set it for ''17'' i believe
if thats is bad...u found a reason why ur not sparking...
when u checked for spark...did u check from spark plug wire...or directly form the coil plug...?
