SpeedRacer1 »
https://forums.nicoclub.com/speedracer1-u311.html
Sat Aug 25, 2007 11:46 am
The KA lower harness will plug into the alternator, starter, oil pressure sender. The KA lower harness will not directly plug into the sensors on an SR transmission. Generally people just solder those connections straight in. The KA has one or two more extra unused plugs for sensors the SR transmission does not have. There are only 3 sensors on the SR transmission, they are the speed sensor, reverse sensor, and neutral position sensor. You only really need the first two. Off the top of my head the wires for the speed sensor are yellow/black and yellow blue for both the KA and SR harness. While the wires for the reverse are green/white and green/blue, should be the same on the KA and SR harness as well.
With an S14 SR into an S13 chassis you MUST use the S13 speed sensor out of either an S13 KA or S13 SR to get the speedo to work properly.
