kouki_monstor »
https://forums.nicoclub.com/kouki-monstor-u33270.html
Wed Feb 22, 2006 4:07 pm
Im in the process of a 5 spd swap, and after i drilled the holes for the clutch pdeal to go in, i noticed something strange. Inside my car, where the holes i just drilled are, are two metal tubes sticking out, directly above the two holes for the clutch pedal bolts to go through. So the bolts would have to go through this tube and out the hole to the other side of the firewall. The weird thing is that, on the clutch pedal (which is an s14 pedal by the way, im installing it into my s13... people on here said they were interchangeable)... well on the clutch pedal, there are also two metal tube thingies surrounding part of the bolts, so when i insert it into the holes, the tubes on the clutch pedal and the tubes on the car get in the way of each other, making the bolts too short to even be seen on the other side of the firewall. i originally thought one tube would be bigger than the other, so that when connected, one would just be placed right into the other one. But after i tried several times, the tubes seem to be the same size, therefore block each other from going in farther. I asked other friends who did the swap but they said they didnt see any tubes... maybe they didnt know what i was talking about? lol...
could anyone please help me on this? would i have to cut the tubes off either the car or the clutch pedal to make it fit? or is there some trick to this that i dont know about? please help!!!
