Broadfield »
https://forums.nicoclub.com/broadfield-u46569.html
Mon Dec 29, 2008 4:04 pm
If you want to tap into the fuse box, then strip some of the insulation back on the wire..... about 1". Then slightly twist the strands, then flatten it out. Take the blade of the fuse and lay it onto the flattened out wire. You will fold the flattened out wire around the end of the blade. So you are basically forming a flat hook out of the wire, then sliding the fuse down into the hook. You want the wire as tight and flat against both sides of the blade. You want to make sure the copper strands only touch the one blade of the fuse. Then you can insert the fuse back into the fuse box. You will simply ground the negative wire to metal or a OEM ground bolt/lug.
