Need help on identifying tube coming off Exhust Pipe
a77ferrel77
Car: 1995 nissan pickup cylinder 2.4l automatic 2wd extended cab xe model
So right off of the header there is the exhaust pipe. Then right below where it connects theres a tube that bolts on and goes up to the Vacuum Solenoid. I would like to know what that metal tube is or get a part number, so i can order a new one but no luck on finding out what its called so any help would be appreciated. Thanks Andrew
a77ferrel77
Finnaly found what it is, for any one that has the same problem and need one its a pair pipe. http://www.courtesyparts.com/14820m-pai ... Path=5388&
