need help on g35 wheel lug pattern!
Shocks, springs, sway bars, coliovers, bushings, brakes, wheels, tires - This is the place to discuss G-Series suspension modifications!
ztuner363
Car: g35
i know the pattern is 5 bolt but i cant figure out if its 5x100, 5x114.3, etc. thank you in advance 4 any help
djamer
Car: 2006 G35 Coupe
I checked Tirerack.com and for 18' and 19' wheels, the bolt pattern for G35s is 5-114.
To make sure, i would just check the owner's manual.
ztuner363
Car: g35
thanks
5x114.3, correct.
Almost all 5-lug Nissan / Infiniti are 5x114.3.
szh
Car: 2018 Tesla Model 3.
Also, be careful about the center bore size too. Not all aftermarket wheels (or mftrs wheels) fit the Nissan. For example, Lexus wheels do not fit as is - you have to modify them - and I would be very concerned about doing that!
Z
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
