Need help on front end conversion and z32 brake conversion??
my91silvia
Car: 91 240 sx going to Silvia
I was wondering if anyone knew of a website with wiring instructions for the triple projector headlights? Also i was need to know what size bolts does the caliper and studs needs to be changed to to convert the brakes succesfully? thanks
onosqv
Car: '92 240sx Vert
Well for the brakes, z32 uses the same bolts as your stock s13.
edit: welcome to the forums, someone will chime in w/ the other answers .
Drift Machine
Car: 1991 KA-T 240sx
Yep mounting bolts are the same, you just need to cut the debry(sp?) shield so the rotors can fit in place. As well as getting brake lines that will have the 300zx style fitting on one side and the 240sx fitting on the other end. http://www.pdm-racing.com has the brake lines for relatively cheap, it's where I got mine.
burnin240sx
http://www.tophatperformance.com has the lines for cheap call mike or scott. they will hook you up. I bought my z32 brakes from scott b4 he worked for THP.
Here's a site I used for refrence on my swap
http://importnut.net/300zxbrakeswap.htm
2s4x0
Car: 1998 240sx
ahahahahahhahaha 10.54 in the 1/8, why do you do that, so people might not read the eigth and think the car is fast??? LOL, my car is slow too right now, so im not braggin, i just think its funny. might as well just say 16.00 in the 1/4.
Eddie
Car: 1995 240sx se
Remember to inatall the z32 calipers with the bleeder vavles facing up.
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
high and low beam projectors plug right into the pop up headlight lamp plug. The fog light projector has to be wired seperatly. I just left my fogs disconnected for now, im going to hook them up to an interior switch later.
my91silvia
Thanks for the help if anyone needs info i am a nissan- infiniti tech but new to the nissan modifying world (sold my eclipse GSX for a taste of the Silvia)
