Correct me if im wrong but the Sr has 203 Ft/lb of torque and the rb20 has 185?silviagtr96 wrote:i'm thinking about buying rb20det do to that i had an sr20det and didn't like it not engough torgue.if i was to install rb 20det in my 240sx and did the regulator bolt on like metal headgasket,front mount intercooler ,greddy blow off vavle,walaboro 255lb fuel pump by the way is that pump be to small if so what pump should i get ,3"exhaust and a boost controller what kinda horse power could i get to the rear wheels and at what boost would be safe at i heard 12-14 psi only until i upgrade turbo.so my email is [email protected] thamk you for the time
Wulfgang wrote:looks like you'd have engough torgue to blow it vavle open if walaboro speakin of that walaboro it not big engough thamk you for clean post good spelling and great punctuation did i forget period i read your post didn't like it not enough english in it
Nope it peaks earlier and lower than the SR.Carl H wrote:no the rb has a hair more PEAK torque but the sr is a torquier motor down low.rb20 shines with its top end potential but if you want a torque motor turbo a ka.
