If I leave the car there for a week without driving it, (either lock or unlocked), the battery will die (volt drop to ~9.5v)
I used a multimeter to test the battery and pull all the fuses one by one, and relays too, and found the following result:
Inside car fuse panel:
The i-key one takes about 20 mA, which I believe is normal
After market alarm (viper 5901) - Check amp draw on ground point
Both armed and disarmed are taking 30 - 40 mA, after it stables, ~20-30mA
Under the hood(I checked both fuse panel under the hood):
The only power draw I found is the two I circled on the picture above
top one draws about 60 mA, bottom one draws about 20-30 mA
Total Amp draw with everyone connected, and
car unlocked, alarm disarmed: ~150mA, after a minute: ~130mA
car locked, alarm disarmed: ~150mA, after a minute: ~120mA
car locked and armed: ~160mA, after a minute: ~120mA
Can someone with more experience on car electronic help me? What could cost the problem?
