NutriaforBreakfast »
https://forums.nicoclub.com/nutriaforbreakfast-u77129.html
Wed May 06, 2009 6:34 am
You need to loosen (not take off) your brake master cylinder cap.
You also need to buy a special tool (approx 5$) from Auto Zone,Oreilley. It looks like a cube and has raised dots on each side tocatch the caliper. It should go onto a 3/8" ratchet since it has a square opening on each side of the cube.
You might also check at Auto Zone or ORielleys about their toolrental. You put the tool kit on your credit card and when you bringit back you get a full refund. I know they have some brake toolkits to rent.
The FSM says you can use pliers but it is just too hard to. Dont giveup your nearly there
