Need help on 8 step wiring...
fastback90
I'm stuck on step four where you wire the grey wire with the black/red wire. I don't have a grey wire on my rb efi plug. Can anyone help me out? Where does the grey wire go? Thanks.
BTW I have a type 2 rb25 engine.
rcodea
i actually have the same problem!!!!!! i have yet to get an answer about this too!!!!
it wouldnt be so bad if someone would tell me what it goes to, but i cant even get that. when i know you will know, but it has been 2 months already, and noone on 4 forums will help me out!!!!! i want this thing started!!!!!
Ryan
gani
Car: cars what else
if you got series 2 then you dont have the gray wire
Joe
exactally, dont worry about the grey wire. if it dosent work without it we can help you fix it.
there are some small wiring diffrences with the type 1 and 2 wiring, the type 2 has no ignition relay or need for an external power for injectors. im assuming this "grey" wire does something related to those. that was my 1 complaint with the 8 steps wiring, he told what to do now WHAT each thing is.
rcodea
i figured the same thing. i just dont have the balls to try and start her with out knowing what i might be not wireing. if you guys really think that it should be fine, thats good enough for me. i'll trya dn get it all done this weekend.
Ryan
rcodea
gani, do youknow what it conects to? i do have a wireing diagram for the rb25, but i dont know what series it is. according to that, the grey wire is conected to one side of all the injectors. does this make since to you? what are your thoughts?
Ryan
HotWIRED
the grey wire is the power wire to the injectors for the series 1.
rcodea
so since i have a series 2, it is another color? or are injectors wired differently? do i just need to not worry about it and start the damn thing?
Ryan
Joe
you dont have it.
the type 2's dont need an external power for the injectors.
and why are you afraid to start it? worst case scenario it dosent start. you arent gonna hurt anything.
rcodea
well, i didnt know what it even went to till today. for all i could have known, the damn thing could have gone to the fuel pump or something crazy like that. now that i know, i will be starting it this weekend, that way if i do have any other problems, i can fix them. thanks for the help guys!!!!!!!!
Ryan
FAST-DATSUN
The gray wire us used to power the injectors on type I harness.
fastback90
Thanks!
fastback90
Ok.. I wired everything up according to the 8 steps wiring except for the grey wire since I don't have one, and my car still won't start. Can someone help me out...
Joe
um, check for spark, fuel, etc
eh?
won't start as in won't turn over? or won't run?
gani
Car: cars what else
check you ignition wiring from the key to the starter. or just turn the key to the on position and get a switch for the starter to jump the whole system. if this does help then go through your wiring again. does your gauge cluster light up when its in the key on postion? if not check you wiring ,battery,grounds
crxcess
Car: 93 240sx fastback
yeah, we need more info on exactly what its doing and what it isnt.... spinning? sparking? fueling? mass air connected?, all piping connected? etc...
fastback90
Firured it out guys... My spark plugs was covered in oil... I just cleaned them up and it started right up...
