Need Help! No spark!
Jagstang
Car: 1995 S14 w/ Kouki S14 SR20DET
Alright, I have just had an S14 Kouki SR engine swapped into my 1995 240sx, and for the passed few days now, couldn't get it to start (only cranks). We checked everything, and the fuel pump is working, and there's power to the Crank angle sensor, and Ignitor etc. There's just no spark (cranked the engine and touched the spark plugs to the intake, 0 spark).
I just installed another CAS (since the one that came with my engine had physical damages on the casing), and unfortunately, that didn't do anything. And today, I tested out an ignitor off of an S13 SR20DET, and that didn't work.
My next thing to test is the ECU, it could be the reason for why my car isn't getting spark.
If anybody can help me out here, that would be greatly appreciated, thanks in advance.
kouki munster
Car: 97 base 240
Are the coil packs grounded properly? There is a ground wire that comes out of the coil pack harness at the back of the head, make sure that you have that securely attached to the head.
Jagstang
kouki munster wrote:Are the coil packs grounded properly? There is a ground wire that comes out of the coil pack harness at the back of the head, make sure that you have that securely attached to the head.
Hey, thanks a lot for the input, but we already checked that ground, and it was tightened down properly.
asoomal
Car: 2001 Subaru Impreza L 5MT (Daily)
1992 Nissan 240SX SE 5MT w/HICAS (Being restored)
Check voltage drop.
Neg batt to coil ground.
kouki munster
Car: 97 base 240
Seems like its time to break out the fsm and go through the diagnostics procedures for a no spark situation.
good2go_240
Car: 1993 Black 240sx Hatch - SOLD
1994 White 240sx Vert - R.I.P.
1993 Burgundy 240sx Hatch - DD
Check every wire dealing with spark, i had a problem just like this and it ended up being a small tear in two wires going to the ign coil and they were shorting each other out.
costa_rican13
Car: 1993 s13 coupe
Ignition control module? And yes check every wire. On my 93 ka. My ignition control module ground wire broke and this somehow shorted out my module. $220 later problem fixed. Been driving since.
Jagstang
Alright thanks a lot everyone for the useful advice. But today I was testing the spark plugs, and realized that there's some sparks in each spark plug. . . And there wasn't any the other day. . . So I took a jumper cable, and connected it to the negative of my battery, and connected the other end to the block and started it. . .
BOOM! It actually started up! But after 3 seconds of bad idle, it died. I managed to capture a video, and during the video, the gas pedal was applied to keep the car from dying. But you can see how the idle is rough as hell.
Here's the video.
Anyways, I think the timing is way off, since the exhaust manifold/downpipe etc was hot as hell after that video was done. . . What do you guys think, if I correct the timing, do you think the SR will run perfectly?
kouki munster
Car: 97 base 240
There is only one way to find out, snag a timing light and get busy.
Jagstang
kouki munster wrote:There is only one way to find out, snag a timing light and get busy.
K, besides timing issues, is there anything else that causes that kind of eradicated idling/stalling issues?
asoomal
Lots.
Lobo240sx
Car: 1991 Nissan 240sx Coupe SR2.35DET Redtop Build
There could be multiple issues. Look for boost/air vacuum leaks, Throttle position sensor voltage, Timing, wiring, coilpacks, etc. You aren't driving a simple NA KA anymore. Get busy. :yesnod
Jagstang
Lobo240sx wrote:There could be multiple issues. Look for boost/air vacuum leaks, Throttle position sensor voltage, Timing, wiring, coilpacks, etc. You aren't driving a simple NA KA anymore. Get busy. :yesnod
Alright, eureka! We realized that the Cam Angle sensor was installed a little off, so we adjusted it, and now the car start up. Here's the problem tho, it idles for exactly 2 minutes a 15 seconds, and suddenly stalls. We're thinking it's either the ECU, or the MAF sensor.
Theory for why the idle suddenly stalls after 2 minutes on every start up probably occurs from the engine running too rich over that short period. Then again, the ECU could also be in safe mode? Any help would be greatly appreciated, thanks in advance.
ciscos13
Car: 89' 240sx hatch, s13 sr
check your wiring. who did your wiring? also check the ground that goes from the engine to the firewall.
Jagstang
ciscos13 wrote:check your wiring. who did your wiring? also check the ground that goes from the engine to the firewall.
Wiring was done by a local SR wiring guru. Everything seems to be working in terms of wiring (everything gets power). I just thought about a few more things. I realized that I forgot to adjust the Idle Air Control Valve, maybe that's causing it to stall out? Or have a high idle?
Also, another thing I realized, my MAF sensor is extremely close to the compressor (about 8 inches away). I purposely cut the rubber hose that connects to the MAF sensor so it can fit behind the intercooler piping, you think there's too much turbulence from the compressor? Might be messing with the MAF sensor?
asoomal
How are the plugs?
Jagstang
Ok, I connected the boost gauge, and I'm reading -20 inHg at idle. So I know for a fact that it isn't leaking cause that's how it should be in idle right?
kouki munster
Car: 97 base 240
Is your ecu throwing any codes?
