irichjohn wrote:please tell me how to bleed it?wer is that 10mm located,any pictures wer is it located?
I think this is what was being referred to.
It's on the passenger side of the engine right in front of the intake manifold. I can't remember what exactly it says, but I think it has some English and Japanese right next to it on that raised spot explaining what it is. Although, I can't see how coolant would ever flow out from there unless the engine was running because it is higher than the radiator cap. The first time I started my engine after changing the water pump I left both that vent open and the cap off and parked the car on a steep incline (front higher), I let it run until around normal operating temp and added water as necessary to keep that rad full. Then I capped everything, filled the overflow tank, and carefully tested it.
