Need Help no Compression
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
calvin208
ok i got a Datsun 720 pickup with the z20 motor. i got it from a family member and they blow the head gasket and so it sat without the head for a few years so i figured i would just rebuilt it but now it doesnt have only compression in any of the Cylinders can someone help
turbojunker
Car: 79 510, 81 720, 72 510-RIP
No compression as in zero? Or is it very low?
flinterman2000
Car: 2000 Nissan Wingroad, 85 Datsun 720 Pick Up.
The ring are probably seized. You need to completely scrap the engine to check from the bottom up.
calvin208
calvin208
im j/w if its got something to do with the timing or not and did the z20 come with the double or single timing chain
PEZi
i wanna say double.... never been inside of a z20 though
calvin208
thanks for the help.
flinterman2000
Yes its a double chain, but that wont help with compression unless the gear or sprocket has no teeth. And if not then too much compression when trying to turn the engine over on one or more cylinders as there is nothing to open the valves. No compression is either stuck rings or holed pistons.
calvin208
I don't know the piston looked fine and the rings are brand new and i heard the timing has to exact
flinterman2000
calvin208 wrote: so it sat without the head for a few years
New dosen't matter over time. If you don't want to scrap the engine try adding some oil and gas mixed to the cylinders - not too much gas - to help with compression and try to start. But I really believe you will need to remove the piston rings, clean the grooves and reassemble.
calvin208
well i dont know so i pulled the motor and found a different one that we put in it. but it has a slight miss in but i thank its vacuum but not sure. but thanks you for the help anyways
Return to “Datsun 720”
