PapaSmurf2k3 »
https://forums.nicoclub.com/papasmurf2k3-u3044.html
Fri Apr 22, 2016 6:02 pm
Not sure what's up with the popping like you mentioned, unless you have a boost leak or vacuum leak somewhere, but yes, the engine revving and the car not going anywhere is typically indicative of a clutch slipping... which happens when your flywheel or clutch gets oil on them either from the rear main seal leakage, or other area.
