dominick1234 wrote:one more thing the radio is very loud at low volume level is this because of the 4 ohm 1 ohm difference?
If you're sending a high level (speaker wire) signal to each amp, it would'could be very loud at low volume. The amp at each speaker is expecting a low level signal (like RCA jacks) and then the amp steps it up from there.
I can't say for sure, but running an amp with high level input, when it's expecting low level input would seem to me like running a 110 volt blender on 220 volts. It would Kick Arse while it ran, but eventually it would be toast.
You might ask someone at your local stereo shop. Better to be safe than sorry.
