need help: need longer lug studs
The_Pretender
Car: 1991 240sx hatch KA NA everyday
i have an s13 and im doing the 300zx brakes on the front. unfortunately the offset on my wheels sucks so i need like almost 10mm worth of wheelspacer to set the wheel off the caliper. yet when i do that much i have no thread left showing on the studs to bolt my wheels back on. i just need to know where i can get some longer hub studs :/
veebee
Car: 2005 EVO VIII
http://www.courtesyparts.com/n....html
2nd set. 50 or 60mm
not sure if that's what you need since i don't know stock length on the s13, nor do i know the offset of your wheels!
but hopefully that helped
The_Pretender
NVM! thanks
Modified by The_Pretender at 9:18 PM 10/25/2006
180fan
Car: 89 fastback
screw that. Go call 1-866-271-0502 and get the 50mm studs. That's the number to Midway Parts out of AZ and 1. prices are better than courtesy, 2. service is better, and 3. they're a nico supporter.
I picked up a set of 10 nismo 50mm studs a couple weeks ago for about 45 shipped with a 10% off coupon they were running last month for Nico members. But even then it should still be less than 65+ shipping.
