mike312 »
https://forums.nicoclub.com/mike312-u63298.html
Mon Jun 16, 2008 11:12 am
Hi All,
I have an issue with a 2000 I30t that I could use some advice on. The info on the problem is listed below. Thanks in advance for any help trying to figure out what the problem is.
INFO:Over the winter, the heat on the car would not blow hot air when the car was standing still. Every red light the car would blow cold air. When the car was running around 45mph continuously, it would blow warm air until I slowed down again. My brother-in-law said at the time if I overheat in the summer, it could be an issue with the water pump. This summer, took the car on a 10hr drive and the temp engine temp crept up to the top at the end of the drive when sitting in a parkinglot with the AC on. This happened both there and back. I have not had any other over heating problems since with 2+hr drives. Anyone have an idea about what the issue might be? I have the feeling that they might be related due to what my brother-in-law said
Thanks
