need help- My fob wont beep anymore
All things Altima Coupe.
nickwillhite
Car: altima coupe
hi and thanks in advance for any help , i installed the homelink auto dim mirror last night and now my car doesnt beep when i lock the doors . The horn still sounds when you lock the doors but i like the electronic beep when you press the button on the handle . I already tried pressing lock and unlock on the key fob and no luck , any suggestions ????
DAAN.
Check with the dealership
Modified by DAAN. at 4:56 PM 12/30/2008
nickwillhite
Car: altima coupe
nickwillhite
Car: altima coupe
do you think installing the homelink mirror , a rear fin with LED tail light , and the 6000k headlights will viod my warrenty
dldjros69
Car: 2012 Evo Gsr
A/C 2.5 Turbo 6MT (SOLD)
Not a chance.
adidas2go
Car: Cycle through all kinds of cars, trucks, motorcycles, and boats 🤙
Once upon a time: 1st turbo Altima Coupe
Disconnect the cables on the battery. Touch the positive and negative cables together. Wait 5 min. Then reconnect the cables. Then try everything again.
nickwillhite
Car: altima coupe
i wi
adidas2go wrote:Disconnect the cables on the battery. Touch the positive and negative cables together. Wait 5 min. Then reconnect the cables. Then try everything again.
l will try that thanks , do you think it might have anything to do with the keys being in my pocket and some how i managed to press the buttons ( lock and unlock ) to cause it
nickwillhite
Car: altima coupe
by the way that is one sick a$$ altima
nickwillhite
Car: altima coupe
no
i tried it and no luck
JAFO
Car: 2008 Altima Coupe, 3.5 SE, Dark Slate
nickwillhite wrote:do you think installing the homelink mirror , a rear fin with LED tail light , and the 6000k headlights will viod my warrenty
The only way this could possibly void your warranty regarding this issue would be if you had to splice into any wires to connect these items. Even then though, you would've had to splice an incorrect wire, the one that controls the "beeping" when locking.
To get back to your problem, as far as I know the only sound you are able to control through the fob is the horn sounding when you lock the car using the fob (you can turn this on or off by holding one of the buttons). I am unaware of any way to manually disable the beeping upon locking/unlocking the car via the door handle button.
If I were you, I'd take it to the dealership for warranty work. None of the aftermarket items you've installed should void your warranty.
nickwillhite
Car: altima coupe
i made sure that i didnt cut or splice on the headlight or mirror mods , i guess im headed to the dealer and thanks for all the help
nickwillhite
Car: altima coupe
hey one last question , where does the electronic beeping come from , is it a horn or something else i looked for a fuse and the only fuse i found was for horn
adidas2go
nickwillhite wrote:no i tried it and no luck
Sorry about that. Thats usually the fixes little electrical problems Try plugging in the stock mirror and see if things go back to normal. Then track the problem from there.
JAFO
nickwillhite wrote:hey one last question , where does the electronic beeping come from , is it a horn or something else i looked for a fuse and the only fuse i found was for horn
I'm not 100% sure for the, but on most vehicles the "beeping" or "chime" comes from a speaker in the cabin somewhere. I assume the fuse for the "beep" would be included with other miscellaneous interior lighting/electrical.
In other words, I doubt the beep has it's own fuse so if a fuse blew, you'd see more things than this inoperable (but it doesn't hurt to check your fuses anyway!).
nickwillhite
Car: altima coupe
thanks for the input im goin to check fuses then i guess i will head to the dealer
brokendan
Car: 09 alitma coupe 2.5s
did you ever get this checked out? im wondering cuz im currently having basically the same problem. no horn or beep. my lights flash when i lock it and do nothing when i unlock it.
nvm i figured it out
jw
Car: 2008 Atima Coupe 3.5SE CVT Winter Frost Blonde Interior
I've have the same issue.
What did you figure out?
michaelthepsycho
Car: 09 Maxima S
nickwillhite wrote:The horn still sounds when you lock the doors but i like the electronic beep when you press the button on the handle.
Huh? My car never beeped... Not the honking, which I know of.
brokendan
heh hold down the lock button and unlock button at the same time for 2 seconds. i had tried this but apparently i wasnt doing it right. but yea. try tht. i tried it again and it worked.
