WhiteyClay »
https://forums.nicoclub.com/whiteyclay-u58544.html
Sat Nov 03, 2007 3:16 pm
ok reply to all..I had similar post here earlier about spacer and mrev2.I ve got Stillen airbox with motordyne spacer and MREV2. I checked the AFR and it was perfect. Crusin it was 14.5-14.7 and while floring it it went down to low 13s.which is good I've check it with a wideband that we connected but your car has duel widebands in your car. One for each side of the car so if it ran lean you will know.Go right ahead and about the strut bar i dont know, never installed it.2 expensive for a piece of pipe with 2 rings.
