check out my instagram I have pictures can't upload to here: nacho300z
any help you can provide will be helpful ty! I'm stuck taking the uber for now :/
i put it up so it can help me out, not for viewsNolimitZ32 wrote:If you want people to look at your pics you need to embed them from a hosting site, not many people are going to go to your instagram (to help you increase your views). I'm not sure which plenum holes you're talking about but if you post a photo I'm sure I could help you out.
i am unsure what to do with this vacuum line
this is the driver side
i believe this one comes from the egr valve (the L shaped vacuum line)
Ran into some trouble guys ... installed the new injectors ,soldered the new connections , connected everything back up. But when i tried to start it ,the car would just crank but not fire up. Does the ecu need a reset or am i missing something.NolimitZ32 wrote:^BOOM, teamwork hahaha
