Just to get some extra info; are you putting a new motor into the chassis? What motor did the chassis have before? Because looking at the wire colors I see cut at the dash plug, it looks like someone had done an SR or CA on this car. Either that, or someone hacked into the harness to put in an alarm or a keyless entry unit. You list your car as a 90 but you landed a DOHC MAF. If you still have the single slammer, you need a MAF from a single cam motor. The dual cam won't work.
The plug at the end of your EFI harness past the ECU plug is commonly referred to as the dash harness plug. It has a few wires on it that transfer some info to the gauges and HVAC control. They should just plug right up. Make sure that the wire colors are matching up between the two and you're golden. As for all the cut wires, I see some splices in your picture, so check to see if the wires weren't cut to add a subharness inline. You might be lucky and only need to re-establish the circuit.
Your best friend is going to be the service manual. I suggest grabbing one from
http://www.nicoclub.com/FSM and go to town.
