nzmoman »
https://forums.nicoclub.com/nzmoman-u41093.html
Fri May 08, 2009 8:00 pm
I would double check the vacuum again. What you are describing has been the culprit in two of my cars. Simple small leaks in a hose that allow you to make pressure but the actual amount of air getting into the engine is less because of a small leak somewhere. I'd hit 7 psi when the car should have been running 9 and it wouldn't make it much past that. It took three rounds for me to find the leak the first time and the second time, I removed all of my piping and just reinstalled it to make sure I got a good look at any problem areas. Also check your turbo outlet neck for any loose piping or bolts or messed up gaskets.
symptoms usually are really bad gas mileage, maybe a near stall at idle, and definitely running rich.
